Gasoline in oil of F115TLRB
  • Gasoline in oil of F115TLRB
    Engine was sitting for a while.Before hitting the water we had new oil change by adding 4.5 qrts. of 10W/30,remove a stuck thermostat.Ran for a while but was suspected of excessive fuel consumption.Upon checking the oil,we found quite an amount of gasoline and the viscousity of the oil was reduced significantly.
    I'll appreciate any assistance possible.I need to hit the water soon,can't afford to sit because the yellow fins started to rip lines apart.
    scalla
    http://www.yamahaoutboardparts.com/c...=000328#000001
