90 Hp 2001' Leaking Oil - Vent Holes
  • 90 Hp 2001' Leaking Oil - Vent Holes
    I'm leaking oil out of the front vent hole above the lower unit and also the small round holes on the side of the shaft housing. Any suggestions?
    Is it 2 stroke oil or lower unit oil?
    Lower unit oil smells a lot different so you should be able to tell.
