I need to replace a thottle cabe on 704 duel control.no sure how to start can someone please point me in the right direction?how hard of a job is it?
yamaha 704 control
need to remove top cover screws, caution they can seize up,4 of em
push one forward/one reverse, pull off cover,has 4 little pin tabs to clear
this uncovers 4 screws holding base to console
then you have 3 phillip machine screws to remove under console which will split the sides, dont lose nuts
then remove the black plastic cover on the side that needs replacing, that will expose cable ends,circlips
if you keep grease on cable ends, usually @ motor, it will help immensly
