I currently flush using the the flush device on the motor. I currently do not run it when I do this and it will eventually push water out of the pee hole. Is this the proper way. I have had people tell me you can run it at idle doing this. I also have friends that still use the ear muffs and run the engine at idle.
What is the correct way to do this and for how long.
