2007 t60tlr
  • 2007 t60tlr
    I bought a 2007 t60tlr and do not have the multifuinction tach. In the owners manual it only covers the alarms with the tach. What should the alarma sound like for overheating, low oil,or water in gas ? Thanks
    The alarm is a buzzing type sound. You can remove that pink wire from your overheat sensor on the block, ground it to test the alarm, and familiarize yourself with the sound. Good Luck!
