My New 1998 175hp I think???
  • My New 1998 175hp I think???
    I just bought a 1976 Mako that has a V6 Yamaha on it. My problem is(well one of them) The guy I bought it from told me the engine is a 175hp. The engine cover says 200hp, and the model number on the transom bracket is c150tlrw. which would leed me to beleive that its a 150hp. how can I tell for sure what motor I have?? Then I have to figure out why I cant get it to even fire at all! Thank you
    That model number is a 1998 non-oil injected 150 hp long shaft model, there is no way of telling if someone changed out the powerhead.
      does it turn over by key ?
      spark ?
      lanyard ?
        It turns over by key. I have 115 to 125 psi compression in all cylinders. But I think I don't have spark on the left side top and bottom cylinders. I think it is really wierd though. Because I can't get it to kick at all. Not even on either??
        Thank you
          check all of the grounds, was it a saltwater motor ?
          ohm test plug caps
            Yea, its a salt water motor
