Tilt piston leak
  • Tilt piston leak
    I have a bad leak around tilt piston on F115
    Mechanic recommends entire lower tilt and trim assembly $2000
    Can this be repaired
    Is this difficult
    Ted
    It can be repaired but you have to find a competent shop that wants to do it. The tilt piston has to be removed and disassembled. A lot of dealers just replace them because of the time involved. If you have the SHOWA style PTT these units are also on Honda and Suzuki and are almost identical.
      Tilt piston leak
      I decided to bite the bullet and replace the part
