Yamaha Flywheel Puller
  • Yamaha Flywheel Puller
    Hello,
    I am about to replace the timing belt on my son's 2001 F80 Yamaha. The belt has stretched beyond specs and will not adjust any tighter.
    My question is will my universal flywheel puller work? If it will what size/pitch are the bolts I will need for the puller.
    If the universal puller will not work or is not the best thing to use what do I need to purchase?
    Thank you
    The harmonic balancer type puller will work, bolts are 8mm.
      Thank you,
      My puller does have the 8mm bolts.
