YAMAHA F80
  • YAMAHA F80
    CAN THIS MOTOR BE MODIFIED TO A F100
    ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ???????????? DOES ANYBODY KNOW
    No not cost effective
      WHAT IS COST EFFECTIVE
      I HAVE 7200.00 INVESTIVED NOW
      COST EFFECTIVE IS A NEW MERCURY
      FOR 7500.00 THAT WILL TURN 5800 RPM,S
      I CAN NOT GET BUT 4900 RPM,S FROM THIS
      F80 MY DEALER SAYS THAT IS ENOUGH
      BUT IT IS MY BOAT AND I AM THE ONE TO
      DECIDE IF IT IS ENOUGH. I WANT 5800 RPM,S
      45 MPH THEN I WILL BE SATISFIED
      THANKLS FOR YOUR REPLY ON WHAT HAS TO
      BE CHANGED TO MAKE MY F80 INTO AN F100
        You would have to change powerhead, carbs and some elect componets. Have you tried diffetent props to get RPM's up
          abut 7 different props
          even had two of those made for me
          no luck
          why change power heads
          yamaha micro-fish says same part
          number along with carbs except for two
          jets and one needle valve in each carb
          electric components check the same
          but i cannot tell if it has a restrictor
          behind carbs or exaust restrictor
          would like to know if this is the only difference
