Thanks for the reply.
Have not been able to check timing while problem is occuring.
The alarm sounds when I pull the float in the oil reservoir.
Spark plug tester shows no spark on 1 and 3, but the plugs test good.
The timing light shows timimg bouncing around on different cylinders (friend/mechanic did this part, I did the rest of the testing)
