Hi, I need help....I am due to buy a used boat with a used engine on Friday...it is a 1998 200 h.p. (s200txrw)....I think it is a salt water II if not mistaken...the compression test was as follows: top left-down 121, 121, 98 top right down 120, 120, 114. What do you guys think of these numbers? Does this indicate a problem? Is this generally a good engine? Please, I need your help...Thanks, Dave.
buying engine
According to the seller, the mechanic "suggested a fuel additive that would easily clean carbon from the pistons, etc. thereby increasing compression." I just don't know if that sounds right. Is this a good engine normally? Thanks for any info you post(ed). I really appreciate it.
dave,
I would have that mechanic do a shock treatment with SeaFoam or RingFree to see if the compression will come up in the cylinder that is 20% below the others. And, yes, if the rings are stuck due to carbon buildup, then an application of a strong detergent can loosen them, and thereby bring up the compression.
If a shock treatment doesn't bring up the compression, then I would be concerned that there may be a broken ring in that cylinder.
Ken K
Â
