I have a Command Link hub from twin 2006 F250s right next to my NMEA 2000 network behind the 3 Yamaha square gauges (port/stbd/fuel) on the dash and one in the bilge, aft by the engines. Can I simply splice a standard CL plug into an NMEA 2K connector and connect it to my 2000 network to display engine data on my (dual) Garmin 5212s or do I need the (expensive) interface cable? If a simple splice works do the wire colors match between CL and NMEA 2000? I currently get GPS speed on the CL Fuel gauge, but I'm not sure how it gets there. Thanks!
Command Link to Garmin NMEA 2000
