Command Link / Triducer
  • Command Link / Triducer
    Hello,
    i had used the search but didn't find the Answer: I hav a Yamaha F70 (buyed 2011) and two digital Instruments. One of these ist the "tach" Instrument with a lable on the backside with the code "6Y8T-11" on it. The second one is the "Speed / Fuel" gauge with the code "6Y80-11" on the backside lable. I want to connect a "triducer" to display the Depth (sonar), ambient water temperature and the speed (waterspeed) on these gauges.
    Is this possible?
    If yes, is the "6Y8-83688-01-00 TRANSOM SENSOR" the right product?
    I only have one hub biult in, the Distance between Transom and hub is about 5 meters, can i make the Connections myself, or do i need a cable between hub and triducer? If yes, which cable is to use?
    Thank you
    BNE
    Yes 6Y8-83688-01-00 is the correct one, will also need a pigtail bus wire to connect transducer to device port on command link hub on boat transom area.
      Thank you for info, i have ordered the parts
