trim down issue
  • trim down issue
    I have 2007 Yamaha vmax 150 on a 285xl stratos I can trim up and down from the switch on the motor ok , but from the throttle ,the leaver on the steering column and the switch on the bow it will not trim down,is there a relay or a fuse that may be causing this problem. thanks for any advice on this issue
    Most likely no fuse or relay. The PTT wires will connect at the engine they usually just loop together. Check all connections for corrosion especially under your helm. Everything works ok at the engine so follow the wires looking for a bad connection.
      ok,thanks for the info i'll check the all the wiring
