no or low voltage from cdi #2 cylinder until engine run at high rpms.
#1 and #3 are fine. Once the #2 starts (voltage from cdi kicks in) it runs great at all rpms and will continue to due so even after the engine turned off for 2-3 hours it will start up fine and run great. When engine is off for 4-6 hours #2 cdi problem occurs again. Has anyone seen symptoms like this
before.
I checked the pulsar, crank, charging coils and they are ok. Help!!!!
before.
