Need help please,I have a 1987 Yamaha 70hp that will run fine and then shut down at high rpms,it then becomes hard to start and idle rough.If I let sit till it cools down it runs fine for a while then it will do it again. I checked ignition with merc spark tester it has fire on all 3 cyl,I pumped the ball made no difference and hit choke and made no difference.
70 Yamaha shuts down at high rpm
Need to check compression. Check for spark at the time it shuts off to see if losing spark, if does then test all ignition components. Check to see if fuel primer bulb sucks flat when engine shuts off.
timing is easy to check with a timing light
and an old motor like that should not be shutting down unless it is seizing up or it is loosing the spark completely.
Testing ignition components like he said is the best thing to do before and while the problem exists to see what is going on
