yamaha c60trlx 1999
  • yamaha c60trlx 1999
    no voltage from cdi #2 cylinder until engine run at high rpms. #1 and #3 are
    fine. Once the #2 starts (voltage from cdi kicks in) it runs great at all rpms and will continue to due so even after the engine turned off for 2-3 hours it will start up fine and run great. When engine is off for 4-6 hours #2 cdi problem occurs again. Do I need a new CDI???? Thank you
    Test pulsor coils, crank position sensor and charge coil output with a peak reading voltmeter.
      c60 1999 tlrx problem
      I did check and output is good --- have you ever seen a problem like this
      before -- Thanks for the assistance
