150 VMAX Surging
  • 150 VMAX Surging
    Would a dirty fuel water seperator filter cause my engine to surge at high rpm(3500-4500) and die when trimming up the engine at the ramp?
    more like water made it past there and to VST tank/filter
      fuel filter
      there is no vst...i tried to get the fuel filter cup to unscrew but it's pretty stout and i did'nt want to crack the bowl the filter looks clear and clean.
      What should I do if water did get past the seperator? I added a ring free shock treatment and I'm replacing the seperator.
        Then remove and clean VST and possible fuel injectors.
          If you would post a model # it would help people know what motor and year you have.
          If no VST like you said then is this a carbed motor or are you just confused?
          If trimming the motor makes it die then I think it is possibly having a voltage problem.
          also May need to monitor fuel pressure/vacuum if it is surging at high RPMs
            150 vmax
            This is a 2007 V150LTR VMAX carb'd 2 stroke engine
            thank you for any info
              Maybe a 2007 V150TLR VMAX not the 2007 V150LTR VMAX you posted
              Monitor the voltage and fuel pressure as I said while problem is happening
                fuel pressure
                how do you monitor fuel pressure and voltage while running down the lake?
                thanks for your help
                  with a voltmeter and pressure gauge hooked up, helps to have an extra person driving while you monitor the equipment
