Wet plugs
  • Wet plugs
    I have a 1987 115 hp the plugs are always wet looking. What gives??Any help is great. Thanks
    Check cooling system/thermostat not allowing motor to ever come up to normal operating temperature, also bad fuel pump diaphragm sucking raw gas into motor. Good Luck!
      Thanks, I will look at that this week end , will let you know how I make out
        hopefully you do mean wet with fuel and not water
          Yes it looks like oiley wetness ?
            Typical in a 2 stroke especially if last time it was run it didn't warm up all the way or if there was alot of idling. The only time mine look dry is right after a good run. Hey it means it's getting oil and that's a good thing.....
            Are there any issues with the way it's running?
              It run ok but sometimes it will idle ruff and not start right up .
