Hello. I have a 2002 Yamaha F25ESHA and I'm looking for some info on converting my tiller steer to remote steer, preferably stick-steer. If I remember correctly, yamaha has offered this kit in the past, but I searched for it just now and did not see a kit. ANY help would be appreciated. I would prefer a yamaha kit, but I would use an after-market kit if a yamaha kit is unavailable.
Remote steering conversion kit for 2002 F25ESHA
If converting to remote control then use number 1 in this diagram2002 F25ESHA Yamaha Outboard REMO CON ATTACHMENT Diagram and Parts Use number 19 in that diagram if only installing remote steering
and Number 1 in this diagram 2002 F25ESHA Yamaha Outboard STEERING GUIDE Diagram and Parts
Then order the Remote attachment kit and the steering link arm.
Still not clear enough, obviously. I need all parts for the conversion, not just the linkage parts at the power-head. For example, the remote control assembly itself. You know, where you actually control the throttle, gear selection, and starter switch? I have nothing but my tiller-steer outboard; anything else that is needed i do not have. I'm going to need more than the remote attachment kit and the steering link arm, but i don't know which control box will work, etc................... Thanks.
Need to replace engine wire harness to remote start engine with
65W-82590-20-00 Eng wire Harness
703-48207-17-10 703 Side Mount Control
Steering system can be purchased from your local dealer.
