Just signed up so hello all.
Towards the end of last summer I had the fuel go off in the carby bowls. Up until that point the engine had always been faultless.
I have removed and completely stripped and cleaned the carby's and blown them out with compressed air. The top carby and the bottom L/H barrel appears fine but for the life of me I cannot get the bottom R/H to fire. Compression and spark are fine. On the weekend I put the boat in the water and off the trailer it appeared fine. Then it dropped a cylinder which seemed to come and go.
I will remove the carb's again and I am considering having them ultrasonically cleaned. As best as I can tell all orifices are clear.
Has anyone else been through something similar? Is it worth looking at the fuel pump do you think?
Any help or suggestions appreciated.
Cheers
Roly
Cheers
Roly
