the motor wont idle at times.if i get it to run it would backfire through the throttle bodies.ive sincronised the throttle butterflies according to the workshop manual with a vacuum guage ,reset the tps & changed the main internal wiring harness,ecu,air intake pressure sensor,the high pressure fuel pump & relay.it would idle perfect at times.
2008 yamaha f225a
Unplug the thermosensor and see if it behaves. If so you know what the problem is. Yamaha is now supplying these motors in Fiji with 2 replacement thermosensors. Should tell you something. My F150 had all these symptoms. Drove me nuts till I unplugged the sensor. Put in a new one and been fine since.
Run a compression and leak down test, check belt timing is corect.
