I have this motor under completion for a future static run, motor was purchased incomplete in the search for a lower unit (got the whole thing for some more money)..turns out I completed it. sensors,pumps,ecm, etc etc.
here is the issue: head is installed, cams checked. valves seated, new seals, new gasket, torqued to specs.
pistons retracted to half cyl. timing belt not installed yet.
turn camshafts lubricated w/ assembly lube, cam journal spec exact. with driven sprockets installed.
Intake cam turns as expected ,(using a 3/8 ratchet on the driven sprocket bolt)
Exhaust cam turns BUT IT IS HARDER not extremely but DIFFERENT than EXHAUST. ..CANT FIND REASON WHY. RECHECKED TORQUES AND VISUALLY RE-INPECTED CAM CAP SURFACES AND HEAD FOR IMPERFECTIONS .
SORRY IT IS F115TXRC 2004
ANY SUGGESTIONS . THANKS!!
