115hp stalls at high speed
  • 115hp stalls at high speed
    I have a 1987 115hp v4 that stalls at high speed.No alarms go off light for oil is green. Will run all day at idle. Did compression test on cylinders found 3 to be at 120psi and 1 at 90psi any ideas. Thanks.
    Thats large difference in compression, might pull that cylinder head and check gasket, cyl. and piston.
