I took the boat out this morning. It ran fine until i was ready to come home. it would start and idle fine. When trying to give it gas and get up to speed, it would begin to spin up, but then bog down hard. it didnt die out, but would not accelerate. the more gas i gave it the slower it would run. i made it home and took a good look at the motor looking for anything wrong. All i found was that one of the clips on the fuel line running from the fuel pump to the upper carb was loose. It definitely did run like it was sucking air. i fired it up at home and it seems to run fine now.
So the question is, could it be that simple? Should i go look for anything else in particular that may have caused the issue.
I had fresh gas and all the proper additives, so i ruled that out.
Thanks in advance for any help
