Command link kit 6y8-we83s-10-00 on 07 key west 2300wa w/ F225
  • Command link kit 6y8-we83s-10-00 on 07 key west 2300wa w/ F225
    I'm thinking about buying the Command Link Communication kit to swap out my analog gauges for digital. I'd like to know my fuel info and hours on engine, etc, etc. I believe that I can use kit 6Y8-WE83S-10-00. Would I need to buy anything else beyond the items listed below that are in the kit? Do I need a cable between the 2 Multi-hub assemblies? Also, I noticed the back of the square meters are round. Does that mean they'd fit inside the openings for my round meters?
    Items in kit:
    6Y8-8350T-01 -Square Tach
    6Y8-83500-01 - Square Meter Assembly
    2 Multi-Hub Assembly 6Y8-81920-01-00
    1 Power Lead, 8ft. 6Y8-83553-01-00
    1 Cap, 2 Pin 6Y8-82582-01-00
    3 Cap, 4 Pin 6Y8-82582-11-00
    1 Speed Sensor Kit 60V-8A4L1-11-00
    1 Fuel Sender and GPS Wire Lead 6Y8-8356N-01-00
    1 Pigtail Harness, Engine to Rear Hub, 12 ft. 6Y8-82521-51-00
    1 Laminate Quick Reference Card 6Y8-2819U-X2-00*
    1 User Operation Guide 6Y8-2819U-00-00**
    1 Consumer Command Link DVD DVD-10660-00-CL
    Yes that kit will work a 07 F225. You also need one Bus Wire to go between the 2 hubs, they are available in:
    6Y8-82553-01-00 1FT
    6Y8-82553-50-00 10FT
    6Y8-82553-11-00 15FT
    6Y8-82553-21-00 20FT
    6Y8-82553-31-00 25FT
    6Y8-82553-41-00 30FT
    You will also need 2 Pigtail Bus wires(one per gauge) to connect gauge to hub:
    6Y8-82521-01-00 1FT
    6Y8-82521-11-00 2FT
    6Y8-82521-21-00 3FT
    6Y8-82521-31-00 6FT
    6Y8-82521-41-00 9FT
    6Y8-82521-51-00 12FT
    If you Cooling Water Pressure to display on gauge then would need
    69J-8A4L0-11-00 Pressure Sensor Kit Gauge will show water temp without having to have pressure sensor kit.
    They will mount in round holes already in dash.
      Why not go with NMEA 2K setup and show everything about your engine on your electronics? Much easier and cheaper!
        Would that give me that hours on my engine and warning codes?
        I'd have to buy the new electronics to do that and that may cost me more than the $950 or so for the Command link set-up. Although, the boat came with an older Garmin GPS/Fishfinder that I've bene thinking about replacing.
          6Y8-82553-01-00 1FT
          6Y8-82521-01-00 1FT
          6Y8-82521-11-00 2FT
          6Y8-82521-21-00 3FT
          6Y8-82521-31-00 6FT
          6Y8-82521-41-00 9FT
          Thank you for the information. Happy New Year!!!
            I see that Lowrance and Raymarine both have the NMEA 2k interface. Lowrance makes a cable that connects directly to the Yamaha and then to the backbone. Can this cable also be used for the Raymarine? The only other cable I've found connects to the Command link system. With that I'd still have to buy the hub and cable to the Yamaha.
              It might but never tried it, I think Maretron makes a data cable that would work.
