Lower Unit Gasket Kit
  • Lower Unit Gasket Kit
    Can someone tell me which parts are included in the Lower Unit Gasket Kit for a 1993 C30ELRR? The diagram for Repair Kit_2 shows #1 as the Gasket Kit. I was wondering which parts were included if I look at diagram Lower Drive_1. If this makes any sense.
    It comes with everything on that parts diagram except water pump parts.
      Thanks for the quick reply.
      In other words it would include 11,12,13,14,15 what about 2,3,17,18. I am assuming the water pump parts are the ones in the center of the diagram.
      Another question if I would order both the water pump repair kit and the Gasket kit would I get all parts shown on that diagram?
        2,3,17,18 are included in lower unit gasket kit, and yes if you get water pump kit and l/u gasket kit you get everything listed except chrome water pump kit.
          Thank you very much for your help. The outboard that I bought had set for a year without any use. It starts and runs fine, it does spit water but I figured I should change the impeller, would you recommend I use the whole water pump repair kit or just the impeller. It also had water in the lower unit there fore I was going for the gasket kit. Am I headed in the right direction?
            Better to get water pump kit if don't know much about history of motor.
              Very good, that is what I will do. Thanks again for your help.
