I know you can hook up the old Yamaha Command Link (CL) system to NMEA 2000 without going thru a Yamaha Gateway by using the Maretron cable.
Does anyone know if the Maretron cable will work with the new Command Link Plus (CLP) network or do you have to go thru a Yamaha Gateway to get engine data onto N2K?
I ask because I'm not showing engine data on my Garmin 5208 but did have it before switching to the CLP (is it me or is it Yamaha?). If you have to go thru a Yamaha Gateway from the CLP Hub to get engine data to N2K, can you instead run two Yamaha Hubs, one CLP for the CLP Display and one CL to connect to the N2K network? (The CLP DEC harness has two plugs, one for CL and another for CLP that connect to the Yamaha Hub.)
