I have a 1992 150 two stroke. Great motor. I keep this boat in florida, so it is tough to keep maintenanced. A couple of months ago I got water in the fuel and had to drain the tank. I removed and cleaned all 3 carbs. When I tried it out, it ran great. I headed offshore, but only got about 3 miles when it sounded like I lost a cylinder. the motor ran like it was a 90. After fishing for the day, I came in and checked it out. #5 cylinder had no power. The plug fired, and when my buddy pulled the plug wire while the motor was running, the rpms never changed, but it shocked him through the pliers. All the other plugs dropped the rpms when they were pulled. I pulled the plugs and checked the compression. All cylinders fine. I then pulled the bottom carb thinking I had a stoppage in the float bowl. Everything was clean. I swapped ignition coils, no change. I changed out plugs, no change. The plugs were always moist, but never fouled, and when pulled, always fired. I had fuel, compression, and fire, but no power. I washed the boat, flushed the engine, and while it was running, I pulled the wire from the CDI to #5. No change. I then pulled the wire from #3. The rpm dropped. I plugged #5 back in and the rpms picked up! I then plugged in #3 and the engine rpms increased, smoothed out for abut 3 seconds, and then dropped again. I had to cover the boat and fly back, so I have not been able to diagnose any more. I hate to spend my vacation time working on the boat any more than I have to. I would rather be fishing. I will be going back for Xmas, and I would appreciate any suggestions on exactly what this problem could be.
Thanks.
Thanks.
