Power tilt and trim
  • Power tilt and trim
    I got a 1993 90HP on a 1993 Maverick. I friend of mine from church gave it to me since he was moving and had no time to fix all the little things going on with it. Well I'm close to finishing the boat but I have one job left. The mechanic that he had working on it, ditched him and left the power trim in pieces. I managed to put the new Orings and seals on it, and put her back together, thanks to this web site and forum. What I don't know is where the two wires for the hydralic motor connect too. Can anyone tell me or point the way?
    The wires from the motor usually blue and green, have to be connected at the power trim relay. Some times the connecting studs will be color marked. If you have a PTT switch at your motor follow the wiring it should lead to the relay. Good luck!!! This link might help http://www.boats.net/parts/search/Ya...RTS/parts.html #34 is the relay.
