Can i swap Square Speedometer with Square Fuel Mgmt./Speedometer Gauge
  • Can i swap Square Speedometer with Square Fuel Mgmt./Speedometer Gauge
    I've read through the forum but i'm not clear.
    I have the square Speedometer gauge and i want to swap it with the square Fuel Mgmt./Speedometer Gauge - is it simply plug & play or do i need to change the harnes?
    Engine is F115 (2012 model)
    Yes you can, just mount gauge and plug wire in. You will need to do the initial setup on gauge when installed but thats it.
