225 o66 high speed
  • 225 o66 high speed
    i have a 2000 225 O66 saltwater series 2 it runs great at low speeds below 5000 rpm around 5100 to 5400 it will breifly stall and regain rpm. i just purchased it last week.
    if this is any help it is a twin engine and the other does fine.
    what to check?
    starts great, idles great, low speed great
    also should they tach more than 5400 at WOT 54mph trimmed out
    1994 27' Ocean Master
    I would go thru your fuel system. Check and clean filters and lines. There is a filter on your high pressure fuel pump inside your VST. Any debris here will limit RPM's.
      rpms are where you should be
      i would also clean/test O2 sensor
