Got a problem. Tried to take the tilt/trim unit off as I had no power to it. Disconnected most things including the body before realising it cant be taken off without the motor being removed. When we started to undo the body part on the port side all the oil came out. No problem with that, just trying to explain what we did. Put it all back together and refilled with oil. Power back probably because of all the movement freeing something up. However all it does is spin. Have tried bleeding it as per instructions in manual but no luck.
I am now thinking that the boby part has not been put back correctly and that it is not meashing with what it is supposed to. Anyone got any ideas?
Boat is moored and I dont have a trailer, only access to a slip at a friends place so I cant take it somewhere to get fixed, and besides the cost of labour even with a mobile mechanic would probably not be worth it considering the age of the motor and its value.
Any help much appreciated. Thanks in advance
