Trim Position Sender Replacement
  • Trim Position Sender Replacement
    I have a 1999 Yamaha 130HP 2-stroke... My trim/tilt indicator on my multi-function tach is not working correctly... I notice that the trim position sender (64E-43139-00-00) is broken such the the plastic ring is completely cracked... I can manually move with my finger the ring that causes the trim/tilt indicator on the multi-function tach to function appropriately...
    My question is whether this is fairly easy to replace on the swivel tube?
    Yes it can be replaced easily.
