300 HPDI Wont Idle
  • 300 HPDI Wont Idle
    Runs kinda rough on the garden hose in gear at idle. Will accelerate and act ok, but when you bring it back to idle, it just dies. In the water it wont idle at all, you have to rev it up to get it in gear and it will run wide open, but as you slow down close to and idle, she dies and will not restart for a few hrs.
    opened and cleaned vst (was very clean inside), replaced filter, fuel lines, and diaphragm pumps, check psi on vst all good. ran on test tank same problem
    cleaned air intake found some dirt and gunk stuck in there
    replaced battery just to be sure it was not a voltage issue
    compression is 120 psi on all cyl
    checked spark with an in line spark tester, and all cyl are firing
    vz300 tlrc 2004 model on a Skeeter bass boat.
    any help would be greatly appreciated.
    We dont have a Yamaha dealer that really knows them around here, just part changers.
    You can try syncronizing the throttle valves. Also adjust your TPS. If your yamaha dealer has YDIS they can check your high pressure fuel pressure, very simple diagnostic test if the technician has any training. It might be an injector issue?
    Do the tv syncro and tps first.
