Got a 2003 F115tlrb that idles at 1500 rpms, ran Yamaha Diagnostics on the motor no active faults. can hear a vacuum suck coming from the Body Assy area behind the throttle body, shot carb cleaner into the area found the joint coming from the isc was sucking air through the holes manufactured into it. I have read both the Yamaha and aftermarket manuals, completed the volts and ohms test, both checked good. I do not hear any rattle from the ISC when I shut off the motor. need some of those great ideas from you guys.
