Well, this is my first post. I am in a bit of a pickle. I had stripped the internal threads on my oil drain on my 2004 150hp 4 stroke. I brought my boat into the mechanic to fix for me, he said there is still some threads left in the upper portion, therefore the stock plug is not long enough to catch those threads. They had given me a new plug (longer than the stock plug), which is from a motorbike which fit perfectly except the head rusted completely. I am now on a search for a replacement (stainless steel), but have no idea where to find one of these and the mechanic told me that that I'll probably need to get one fabricated. Can someone out there please help me with this and let me know if you know of a company that has them....
Engine Oil drain plug
I don't know of a plug that would work, may be able to install a heli-coil to repair threads but never tried it and sure if would be possible to install one.
This company sells quick drain plugs but also adaptors. Give them a holler and see if they can help.... They may have a longer bolt.
IMHO, I would put a longer one in permanently with a slightly smaller opening in it for a smaller plug. The wear and tear would be on that and NOT on the little bit of aluminum threads left in the block...
QuickOilDrainValve.com - the best way to change oil
This other site has magnetic specific drain plugs of different lenths:
http://www.magneticdrainplugs.com/mo...rain_plugs.htmLast edited by TownsendsFJR1300; 10-18-2011, 07:21 AM.Scott
I've heard Rodbolt and a few of the guys mention not using the drain plugs to change the oil due to the threads messing up. They recommend pumping the oil out of the dipstick hole, much easier and quicker without the thread problems. Maybe once you get your new stainless plug in there, consider the pump method? I don't know the size or length of your drain plug but Autozone and other parts stores carry a good selection of drain plugs of various diameters, some with magnets and some without. Good Luck!
