Z200 Hpdi oilgauge problem
  • Z200 Hpdi oilgauge problem
    Hi,
    i Have a Yammie Z200 HPDI. The oilpump in the large tank pumps the oil to the small oiltank when i switch on the power. However when the small tank goes empty she does not refill. Alarm does go off.
    When i switch off the power and back on again she will fill up again.
    Anny suggestions?
    Marlon.
    You didn't say if you have Yamaha gauges with oil level lights, if do what light is on?
    Probably need to test oil level sensor in engine and remote oil tank, check wiring harness and connections to remote oil tank.
