Diagnostic Icon.
  • Diagnostic Icon.
    Hi I have a new Yamaha F150. I powered it up this weekend in a very large tub with the prop removed. It started straight off and is running well goes in and out of gear and all seems ok. I then noticed the engine icon was blinking on the command link guage. I switched the engine off and checked under the hood for anything obvious all seemed ok. Have subsequently restarted it a couple of times and run it for several minutes. The problem has not reacurred!!!
    Has anyone experienced this before any suggestions or reassurance would be gratefully received.
    Martin
    England.
    If didn't sound warning buzzer then it's not a critical fault, if light comes back on then it needs to be checked.
      Thank You. Boat gets sea trials this weekend for the first time so will keep an eye on it.
