Idles rough, push into FWD gear and will not go above 1400rpm Stalls out when returned to neutral position, thought it was the fuel, drained & Cleaned carbs, drained some fuel from tank to check for water (None), removed bulkhead fuel filter/water separator and cleaned. Replaced the plugs, seems like cylinder 1 is not firing, pulled #1 plug wire and restarted runs the same as before, replaced #1 wire and pulled #2 restarted and runs worse, replace #2 wire and pulled #3 and runs the same as when #2 was pulled, could a coil have gone bad?
Thx for any assistance......
Gary
Gary
