I need your help picking out the best plotter for displaying my f-250 functions. I know it has to be NEMA 2000 capable to use the command link harness. Any recomendations?like to get by with 1,200.
Chart plotter for f-250 function display
If you go to store that has them set up on simulators like a Bass Pro, West Marine or Dealership, then you can compare them to see which one would work best for you.
The F250 will need to be a 2006 or newer model to be Command Link compatable. You will Command Link network installed(unless GPS unit you purchase has adapter to connect direct to Yamaha engine) and connect a Gateway model to CL hub in order send engine data to a NMEA 2000 network.
If your motor is a F250XCA or F250UCA model then the Yamaha color Display unit will work on it and display all engine data on one unit.
The Yamaha Command Link Plus color display wont work on your model motor. You can use Command Link Square or Round gauges that will display engine data.
I'm sorry I didn't read your post carefully enough, model number F250TXRD is a 2005 model year motor and not Command Link compatable, the 2006 and newer models end in TXR(no "D" or any other letter on end) which are the first models Command Link and NMEA 2000 compatable.
No only the 2006 model year(manufactured date 2005 or newer) and newer motors are NMEA 2000 compatable.
ÂÂÂ
