I have a 2004 F150TXRC Yamaha outboard it puttered and stalled out on the waterway. I seems to not be getting any fuel to the injectors. I disconnected the fuel line at the top of the fuel rail and turned the key. Fuel did pump pretty fast from this line. I cleaned the throttle body with some injector cleaner and the engine starts for just a few seconds until the cleaner in burn't off but it just will not start otherwise. why will it fire up with the cleaner and not normally. It seems to me that the cleaner is making its way past the injectors. what do I check or replace at this point???:
Troy
Troy
