Hello
Can anyone tell me where I can get a wiring diagram for twin 2004 200 hpdi 2 stroke engines. I have these on my 2004 2870 Pursuit. The port engine would not sound the start up alarm when turned on and therefore would not start. Troubleshooting found low voltage and a yellow wire getting hot going from bundle to the key switch and also back to the engine. With process of elimination I am thinking it is a short somewhere in between there and the engine. Took the cowl off the engine. could not find said yellow wire, moved the wiring around trying to find the yellow one - and it started working with good voltage. Would like to get the diagram so when (and I know it will) it happens again, I would be able to see what the wire is connected to and hopefully fix it. Thank you for any help.
