what prop size?
  • what prop size?
    I have a Yamaha F25ELHZ 4/stroke 25 HP. I would like to know if it is possible to up the HP? It has a 9 7/8 x 10 1/2 F prop on it. This motor is underpowered for my boat due to lake restrictions. I have installed [Smart tabs] on the boat which has helped get it up on plane.Can I change to a bigger diamiter and different pitch prop? I dont have a tack on the motor so
    I dont know the RPM . I dont know the weight of the boat but it is rated for
    a 60HP tiller. Thanks for any imformation. MWick
    You could go to smaller pitch prop but will increase rpm's at full throttle and may overrev if you are already running on high side of rpm range now. 8 Pitch prop is the smallest available for that motor, 2001 F25ELRZ Yamaha Outboard LOWER CASING DRIVE 2 Diagram and Parts
