My 2007 Yamaha F115 has developed a problem running at high RPMs. After I have been running at around 5500 RPMs or higher, the RPMs quickly drop to 4500, and then the boat takes off like a scalded cat. The problem is intermittent. I can run several miles without it happening.
I checked the 10 micron water separator and the gas looked good. There was no water and maybe 5 particles of some kind of sediment. I replaced it anyways. It has a full tank of fresh gas. I used the boat all summer without issues. I always use Marine Stabil for E10.
I pulled the spark plugs and they look good. I also checked battery connections. The fuel bulb is staying hard.
I'm still in the Yamaha Extended Warranty. I took it to the nearest Yamaha service center which happens to be a Cabela's. They see the sudden RPM drop in the ECM history when they hook it up to the computer. There are no error codes. At the same time they see a drop in battery voltage to 10.6V. They also see the throttle postion sensor doing something, but that may be when I backed off the throttle when the problem occurred. They are stumped and called in a Yamaha field service rep. He's contending its a fuel issue.
I don't believe its a fuel issue because the boat has been in use, the behavior comes and goes so quickly, and a severe voltage drop observed in the ECM. I think it is definitely electrical. The service manager at Cabela's agrees and is bringing in a dyno load from home to run it under load at the shop tomorrow.
Has anybody see an F115 with this behavior?
