I purchased this remote as I was told here that it would work with my 1987 15ELH. The shift works fine, but the throttle works backwards. Instead of pulling the throttle lever to open it, which the instructions say it's supposed to do, it pushes the throttle lever, which doesn't work since the throttle is already closed (and I'm assuming here that "pull" means to pull the throttle lever towards the front of the boat and "push" means push it towards the rear).
There is a section in the instructions which tell how to change the throttle control from a pull to open to a push to open type (with the purchase of a different part), but I don't get the connection since it seems to already be pushing instead of pulling. Can anyone help?
