2006 Yamaha 90 HP 4 stroke
  • 2006 Yamaha 90 HP 4 stroke
    Just attempted to change from alum prop to S/S prop and the S/S prop
    hits the trim tab. What should I do? Charles
    Apparently you did not stay with the same size prop as the old one.
    Probably best to find the correct diameter SS prop, but you can go to different pitch
      Grind a bit off the trim tab for clearance....
