Duel Engine Fuel Management kit for F-stroke 90
  • Duel Engine Fuel Management kit for F-stroke 90
    Could you tell me the part number for Duel Engine Fuel Management kit for a pair of 2006 Yamaha F90TLR?
    Thanks Craig
    Need to know what gauges you have now. Do you have any gauges, do you have Yamaha Multifunction digital gauges, do you have Yamaha Command Link gauges?
      Only multifunction digital Tach's. Not Yamaha Command Link gauges.
        The Yamaha Multifunstion Fuel management gauge for twin engines is part number 6Y5-W0088-64-00 but would require a Yamaha multifunction Speedometer or connected to a GPS in order to display MPG.
        You can change to Command Link gauges for about the same price or little more depend on gauge set you want and it works better for fuel consumption readings on fuel injected engines(as long as you have 2006 or newer engines).
