Searched and found lots; but not my problem. Only the stbd side works. Swapped the harness' on the sending units and same thing. So that's telling me the sending unit is good and there's a problem with the gauge. Just printed out the installation instructions to check for bad connection etc. What experiences does anyone have with this particular problem? Thanks guys.
Fuel Management Gauge
Is the arrow on bottom pointing to "TTL"? If press the set button is pressed will gauge change to "P", "S" or "PS"?
Originally posted by boats.net View PostIs the arrow on bottom pointing to "TTL"? If press the set button is pressed will gauge change to "P", "S" or "PS"?1999 Grady Sailfish SX225 OX66
The fuel management gauge connects to both tachs and it uses the tach signal along with fuel flow sensors to determine port and starboard engines, so need to make sure getting tach signal voltage to the green and green/white lead at FMM. The fuel fow sensors can be checked by removing them and blowing small amout of compressed air through them to spin paddle wheel(too much air pressure will damage sensor) and see if getting reading at gauge. The flow sensors and wiring to them are the most common problem.Last edited by boats.net; 09-21-2011, 08:54 AM.
Thanks Bobby, can confirm leads from gauge connected to both tachs. Will a bad sending unit cause blank screen? I'm not seeing P, S, or PS. Completely blank screen. Other than physical test of sending unit (blowing through it) what readings should I look for on each lead on the sending unit? Will take apart unit as a last resort. If I tear the gasket, I buy a new sending unit. Thanks.1999 Grady Sailfish SX225 OX66
Does the mode button toggle between TTL, Econ and Sync, if not gauge may be bad.
The manual does not state specs on sensors but you can compare readings on both sensors when applying air to paddle wheel to see if one is bad.
Â
