First post here so I want to say hello to everyone and thanks for any assistance. As stated, I have a 2005 90 hp 2 stroke. On the last 2 trips out when running wide open, I throttled down when passing through some floating marsh grass. Upon increasing throttle, alarm went off and water peeing seemed excessively hot. After turning off and letting motor sit for approx 15-20 minutes, alarm went off and boat ran fine with no indication of problems the rest of the day. I was thinking it may be the thermostat. Honestly, I'm not excatly sure where the thermostat is, but would like to try and repair myself. I was thinking it was the small rectangular box with aluminum cover near the plugs?
Also, motor has always idled a little high. Is there a simple method of lowering the rpm when idling?
Thanks again for any advice!
